Stud wall in a garage
I'm looking to build a stud wall in my garage. This wall will basically cut a double garage (cars end-on-end not side-by-side) into a single one. Although the existing walls are only single skin I plan in due course to insulate them fully. Although I can find loads of info on building a basic stud wall this one - as the garage is uninsulated and has an external temperature- will presumably need some heavy duty insulation. Can anyone point me towards some info on what insulation or damp proofing is needed?
Also - would this need building regs approval.
Shrewsbury
You will need building regs if it is a change of use, i.e. if it is going to be used for living in - rather than just storage. I am in fact now sitting in a room which used to be a garage. It was done before we moved in, but our solicitor had to obtain a copy of the building regs.
More info: The floor has been raised - they put in a suspended wooden floor over the concrete garage floor. The walls have been insulated (should be waterproof anyway?) - I am guessing that the fixed suitable timber battons to the wall, then insulation panels, then plaster board.
I hope this helps.
p.s. you can by rigid insulation panels with a great u-value (insulation value)
