Skirting ideas for round structure
Hello,
I would love to get suggestions on how you would skirt this yurt on a raised platform. The intention is to keep the yurt floor warmer and prevent rodents and especially snakes from making this area their home.
Thank you very much!!
Interesting project....looks nice....I had to "Google" the word "yurt".
Anyways, this is a bit tougher. I gave it some thought, but with esthetics in mind. While there are options of products you could skirt the yurt's & deck's floor with, they would look bad.
Here is what you might want to consider:
1) dig a trench around the perimeter of the vert and deck where you want the base of the skirting.
2) form (used cedar or weather-treated wood) a vertical frame in which to mount future plywood skirting
3) cut your strips of weather-treated plywood (length is 8', width is HIGHT of SKIRT). Skirt should go 10-12" below the surface to keep rodents from too easily digging beneath.
4) wet/soak plywood strips, and begin to screw them onto the frame. The wet plywood will permit it to flex. It'll dry in place. This could take a while.
5) Staple black paper, wire mesh the plywood, and apply stucco with texture to suite. Stucco can be colored to suite.
Rats just love to get under raised structures.
Can't speak for snakes.
Rats will chew through anything until all their teeth break.
I would put a perimeter "fence" of chicken wire or better still, welded mesh, all the way round and bury it another 12" down.
Invest in a good terrier rat catcher for good measure.
