How to insulate a sunroom made of aluminum and fiberglass?
My add-on porch has lots of windows and is made of a fiberglass roof and thin walls. I would really like to insulate it. The biggest issue is the ceiling/roof. It is low enough that I'd rather add insulating material to the outside so as not to lose ceiling height. I could add panels of rigid foam to the walls on the inside, so lets keep this discussion to the ceiling. Thank yo so much! have attached a pic of the type of material it's made of. It has no wooden reinforcement. but the picture illustrates the actual type of roofing
You have already built this ? Id the corrugated material translucent ? If so , is that a deal breaker ?
You wish to insulate to keep the heat out or the cold out , or both ?
Wyr
God bless
FWIW, aside from anything else, keep the insulation dry once you decide what to use. Wet is bad and it will probably never dry out if water gets to it
