Residential Wiring Mystery - Lights/Switches
Poulsbo, WA
Hello, I'm new here, so hope I do this right... I'm homeowner, recently bought home (built 2003). I've had two different local elect contractors come out with no resolution - although neither went into attic to trace wiring, only used tools/meters at the lights and switches. At their rates I'm not inclined to pay for a 3rd service call... I'll do my best to describe the issue here.
Lights/switches involved:
> Single ceiling Dining Room light with three separate switches - one of the three is a dimmer switch.
> Single Bathroom vanity light with one switch. (there is a 2nd switch in the gang that controls the exh fan, but that one does not seem to be involved in the issue).
Mystery:
> If the dining room light is on 'first,' the bathroom switch will not turn on the vanity light? (the switch for the exh fan still works fine)
> If the vanity light is on 'first,' it has no effect on the dining room light/switches - all three switches will still turn on the dining room light independently, and the bathroom light will remain on until switched off. In this scenario - both lights on - if the bathroom light is switched off and the dining room light is still on, then the bathroom switch will not turn the vanity light back on?
Although I have done many electrical tasks over the years with no issues (repair, replace, add breakers with new loads, etc.), this seems to be one I can't sort out in my mind. At 74, I'm not inclined to climb around in the attic anymore and simply run a new/separate line - I'd rather an existing issue be corrected than just capped or hidden.
Any pro knowledge, including what to look for IF I DO have to get into the attic, will be greatly appreciated. Thanks
Baton Rouge, La.
Mr Brad, I am not a professional electrician but have done a lot of electrical work.
It sounds like who ever wired it took a hot wire from one of the 3 way switches in the dining room and feed the vanity or vise versa.
3 way wiring can get confusing.
If I were you I would open each switch that is involved and try to figure out what wire is what. If the vanity light switch is close to any of the dining room lights I would look closely at the wiring of those 2 switches. I also would get a wire tracer to help with that. Harbor Freight should still sell one cheap that works great or Amazon.
Hope this helps.
This is a classic case of a shared neutral wiring error or miswiring at a switch leg, likely due to an improperly wired multi-way switch loop sharing a junction or neutral with another circuit. Here’s the breakdown of what’s likely happening and how the symptoms fit:
Summary of the Mystery
  • Dining Room Light: 3-way switching with a dimmer involved.
  • Bathroom Vanity Light: Single-pole switch.
  • Problem:
    • If dining light is on first, bathroom light cannot be turned on.
    • If bathroom light is on first, both lights work independently.
    • But once the bathroom light is turned off while dining light is still on, you can’t turn the bathroom light on again until dining light is off.
Most Likely Cause: Shared or Interrupted Neutral
There are two strong possibilities:
1. Shared Neutral Conflict
  • The bathroom light and dining room lights share a neutral wire back to the panel.
  • The dining room circuit has a 3-way setup (i.e., hot from panel goes to one switch, switched hot leaves from another, and a traveler pair connects them). Sometimes during construction, electricians will pull neutral for the bathroom from a nearby box, such as the one used for the dining light.
  • If the dining light switch interrupts that shared neutral (e.g., via dimmer electronics or odd traveler behavior), the bathroom light won’t complete a return path, even though it has hot.
2. Improper Switch Loop (Neutral Not Carried)
  • The dining room setup may use a switch loop (older code allowed hot to go to switch and return on white as hot), and somewhere along the way, the bathroom light’s neutral is improperly tapped off a switched wire or traveler.
  • When the dining light is on, this may pull the bathroom’s neutral to a floating or hot state, preventing the bathroom light
Why the Behavior Matches
ScenarioExplanation
Dining on first, then try bathroomBathroom’s neutral path is interrupted or “floating†due to load on dining circuit
Bathroom on first, then diningNeutral is intact at first; both circuits work while bathroom remains energized
Bathroom off while dining onNeutral path remains compromised; no return path for vanity light
What to Check (if going into attic or boxes)
If someone does go into the attic or opens junction boxes:
  1. Trace Neutrals:
    • Make sure each light has its own dedicated neutral wire that leads directly back to the panel or its circuit.
    • Use a multimeter to measure voltage between hot and neutral. If you see odd voltages (e.g. <120V or fluctuating), you likely have a shared or missing neutral.
  2. Check for Bootleg Neutrals:
    • If neutrals from separate circuits are connected together, it violates code and creates cross-interference (especially with dimmers or electronic switches).
  3. Open Each Box and Photograph Wiring:
    • You or a younger electrician can open the dining room switch boxes and bathroom switch box and check:
      • Are any white wires connected to dimmers or switches directly? If so, they may not be true neutrals.
      • Are neutrals bundled improperly across circuits?
  4. Dimmers Especially:
    • Some dimmers require or “fake” a neutral and can confuse the system if one isn’t present.
Fix Without Climbing?
If you want to avoid the attic:
  • Hire an electrician who understands shared neutral diagnostics.
  • Suggest using a circuit tracer or voltage drop test to locate shared or interrupted neutrals.
  • You may not need to rewire — just un-bundle shared neutrals and run proper neutrals to affected fixtures if accessible in switch boxes.
Conclusion
The odd interaction is almost certainly due to shared or misrouted neutrals between the bathroom and dining circuits. This is not just a quirk — it’s a code violation and potential fire/shock hazard if neutrals are overloaded or incorrectly shared.
