Need advice plastering here.
Advice on how to finish of these door rebates after new door installed. I can plaster of sorts but the needs preparing for undercoats. Shall I use plaster board or mortar? Sorry images need rotating 90deg. Thanks.
If you use a drywall board, consider using the type that avoids paper and thus is able to handle moist environments. Greenboard I have heard it called because some is green. Mainly specced for bathrooms or moisture areas. That brick is a moisture area.
