Cheap trolley.
Whilst visiting Aldi yesterday I noticed the neat trolley shown in the pictures below. I'm planning to make a new welding trolley and will need four castors; at £10 for this trolley problem solved. With a maximum load of 250 kg these small trolleys would be handy for many moving tasks.
Good price! I meant to pick one of these up years ago, as it would have been so useful when moving things... but I've not needed one since. As soon as I do, I know where to go :D.
When you do need one Ian it's highly likely Aldi won't have one in stock? When I visited Aldi again all the trolley's had been sold.
It's been a struggle getting into the workshop due to being retired and not having enough time each day. However I've just enjoyed an excellent day in the workshop today so can post a bit of progress. My new TIG welding trolley is coming along nicely and is made mostly of offcuts of steel and 18mm thick plywood. Quite a while ago I bought a load of steel offcuts so am steadily using these up and the plywood is bench shelves I cut out to make space for my Oxford welder trolley.
My Oxford arc welder (Pickhill bantam 180A) in the trolley I made. I'm using this to weld the new TIG welder trolley.
Angle iron base frame welded.
Corner uprights welded.
The cheap Aldi castors in position; please note row of screws securing plywood divider.
Plywood secured and divider located; corner top for cylinder yet to finish off. The TIG welder will sit on top and beneath there is storage for welding odds and ends.
Testing gas cylinder for fit; just the corner to finish off. It's imperative any cylinder is supported safely either similar to this or strapped to a wall; cylinders are highly dangerous and command utmost respect. Progressing nicely.
As usual, a good job Colin :). I particularly like you using the arc welding to make the TIG welding trolley!
Thanks Ian. :)
Offcuts of metal; two pieces of 18mm thick plywood and four casters make for a cheap welding trolley. The trolley tucks neatly away but is always ready for immediate use.
I've never yet done any TIG welding but once I know what I'll be using I can make use of the storage space available within the trolley.
Gauges added together with a gas flow meter; all I now need is time in the workshop which I find difficult to get.
