Heating Retention in Small Condo
Hello! New to the forum, happy to be here!
I am the owner of a 1BR basement level condo. However, there's an issue that plagues me each winter.
1.) My unit appears to be lacking in terms of weather proofing. There is a front door that opens to the interior of my building (which is a mixture of condos and rented apartments) and a backdoor which opens to a patio. When temperatures drop below ~40 degrees Fahrenheit, the unit becomes uncomfortably chilly, even with the heat cranked to ~74.
Last year, I had a handyman do some weather proofing work on the back door and it helped somewhat, but in the midst of another winter, I can't say I'm especially comfortable in my own home, have to wear multiple layers of clothing to not freeze.
Things are better in the bedroom, and when I close the bedroom door, with the heat on, it's comfortable.
Do I have any further options I can take to increase heat retention in my unit?
Thanks for any input you might have.
Welcome to the forum. My guess is it’s your windows and doors. Modern thermo windows can make a huge difference in comfort. Place your hand on the inside of your windows. If the glass is freezing cold you are loosing heat there.
There are LOW-E window films that can be applied to existing glass. It is better to replace everything of course, but since regular glass emits roughly 93% of the energy that comes at it, dropping that surface emission below 30% or even below 10% is going to have the heat retention effect you are after for far less money than replacement. The window frames have losses to though so it is a partial fix.
