Crack!
A couple of years back I had some internal walls removed around some cupboards.. Where a new wall has been built against an existing wall a crack has appeared. It seems that the wall has not been joined correctly.and maybe has a straight joint??????
How can I get this repaired as all attempts to conceal the crack have failed, including the use of good flexible filler.
up the junction
I wonder, what were these internal walls, stud partition or brick/block? and I assume the new wall was built against what was the back wall of these demolished cupboards?? so can I ask why???
bosshoggo_O
