Mortar Raking/Grinding
Hi, please can you help! I'm searching for some kind of tool that'll easilly remove mortar from hard to reach areas, for example behind drain pipes, etc.
I was wondering if there is something like a tiny angle grinder, maybe the size of a battery powered toothbrush which I could attach say a 1-2" grinding wheel?
The closest tool to my needs I could find was the Merlin mini grinder but it's a chainsaw so I'm unsure if it'll be suitable for grinding out mortar, however it's possible to attach a tungsten carbide disc so maybe it would be suitable just for the hard to reach areas.
Can someone recommend a smaller or better tool than the Merlin mini grinder or could you share your experience if you've used the Merlin?
Thankyou! I look forward to Reading your replies. Touch wood!
