Hot tub issue
I just picked up an @home (Dimension One) Dream spa. It was free so I think I got a good deal. The water heats up and the pump runs on low to filter and when turned on. When I turn the jets on high sometimes it will run just fine and other times when I turn the jets on high the pump shuts off and I get 3 blinking dots on the control panel. The control panel continues to show the correct temperature. After a few minutes I hear a relay click and the pump can be turned back on low and it will run. Otherwise everything seems to be working well. Does anyone have any ideas?
I have adjusted the pressure sensor and it helped some, but still after 5 to 10 minutes it shuts off when on high speed. This happens with the filter out as well.
