- Joined
- Dec 10, 2018
- Messages
- 4
- Reaction score
- 1
Two weeks ago, In my back yard I heard 'ZiZiZi..' sound. It was like electric wire touched water and got short circuit. I followed the sound and found there was water leak in the pipe and valve. The electric wire for the sprinkler valves got messed up and under water.
1. Replace the leaking valve
I went to the local store called "JC Plumbing 'N' Things" and bought a new value to replace the old 3/4 inch valve as chart shows
old valve;
2. Obviously the electric wire got wet and tend to be short circuit when there were water leak or when it was raining. I bought wire connector from amazon and reconnected them using the wire connectors so that it could be waterproof as I also used tape to enhance it. The ‘ZiZiZi..” sound disappeared even though the wires touched water.
https://www.amazon.com/Connectors-C...hant-items&ie=UTF8&qid=1544919044&sr=1-5&th=1
I realized that As long as I can spend time to try it by myself, sometime, I can also get it done well for the small problems in the plumbing system.
old valve;
