Hi everyone,
Beginner DIY here. Im going to attempt to build a work table for my garage out of a few old bed frame materials and maybe buy a sheet of plywood for the top.
I've got these planks(21pcs) that are 7 1/2" wide x 39" long about 5/8" thick
And I've got long pieces(6pc) that are 5 3/8" wide x 75" long about 1 1/8" thick
Attached Photos of pieces I'm working with, also solid wood headboards(not pictured) available that I can cut down if I need any more.
So far my game plan was to glue the smaller planks in 2's so theyd be about 1 1/2" thick and use these for legs (cut to size).
Then use the long pieces as the sides of the table; length wise. 4 pcs total for bottom and top. (will keep it close to a 75" long table height maybe around 34")
And screw them all together with some glue, just straight screw wood into wood (at 90 deg?)
Tools I have: Jig saw, circular saw, screw drivers, glue, drills, square, bubble leveler, light duty clamps.
Is this going to be a terrible table? Any ideas or things to change?
I have 0 experience. Any input helpful!
