Wiring a new metal light fitting
Hi all
New poster here...
I'm replacing the main light in our sitting room at the moment with a metal chandelier type (a B&Q 'Eva' chandelier). The wires dangling from the ceiling are:
- Bare copper earth
- Red
- Black
- Red with black tape (presumably for switching)
The light fitting has the new colours and has live, neutral & earth all screwed into a 4 slot terminal box strip, with one slot free.
I've matched up black & neutral, copper & earth, and the switched red & black to the live, and have put the red to the remaining spare slot.
The light however, doesn't work. Is my wiring ok, or should I be looking for another issue?
Cheers
I should probably just clarify what I mean by 'doesn't work'...!
In the room with the light I am changing there are wall lights also. The wall lights do not now switch on - previously they did and the main light did not.
I worked out that the main lights didn't work as the bulbs had blown that came with it. I found a bulb which fitted it, and the main light now seems to work...but on the switch that previously controlled the wall lights, and now the wall lights don't work!
Any help?
A further development... if I screw all the non-working bulbs back into the main light, with one of the bulbs (which does work) in there too, now none of them work and the wall lights do!
I suspect my wiring may be scrambled. Any takers for this one?
