Wet Bath Sealant
I came home the other night to leaky shower had been dripping on to one of the taps and splashing into the corner - resulting in small pool of water and wet crumbed sealant in corner (see picture) i have dried out and cant see any obvious damage under the bath of what i can see of plasterboard other than stuff that looks very old.
When removing sealant should i replace straight away or leave gap to dry out
It may be worth cutting/remove the sealant as it looks like it's lifting and has gone mouldy, airing the space for a little while if it looks wet underneath, then re-sealing it. If it looks dry once removed, there's no need to wait before re-sealing.
FWIW, I've always found these sealant finishing tools make for a really neat job:
https://www.amazon.co.uk/Unibond-1582528-UniBond-Sealant-Finishing/dp/B001DZTYG2
Thanks for the Info
I noticed it Monday, getting it cut out tomorrow morning and patched up then resealed
The best bet with this is to completely remove the sealant for some distance from the corner. A new utility knife blade will do this. There are many sealants available now and not all are silicone. Silicone sealants cure to a distinctly rubbery form whereas the "modified" silicones don't feel the same. It's just that I wouldn't be confident mixing the two.
The modified silicones will cure on wet surfaces, but I would recommend a thorough dry with a paper towel. Also use a paper towel to see if water squeezes out from any of the other sections of the seal.
If you go for silicone, get a sanitary grade to help prevent the mold staining.
If the bath has a curved edge, try and get the new silicone well squeezed into the gap.
For a neat job, mask off the the area. Sealant tools do work but can spread a thin film that later on will lift.
Seals don't last for ever, especially if "scrubbed". Sometimes it's better and easier to replace it completely.
You can get self-adhesive corner seals, but in my experience they don't work.
onward
