Kommerling glazing bead removal.
I am having trouble removing Kommerling glazing beads. I bought a special chisel-like tool. Inserting it between the bead and frame is no problem, a!though slight damage is caused, but the bead will not move significantly. I am starting in the centre of the longest bead as advised but the bead is such a tight fit and I fear causing damage. A previous unit I changed had overlapping beads which were easy to pry out at the corners. This unit has mitred corners which cannot be removed in this way
Staff online
