Door Frame Crack
I've notices a crack appearing on the vertical part of a door frame. Is this something I should be worried about and how would i go about fixing it?
Welcome to the forums :).
Do you mean the crack between the frame and the blue wall? As long as the frame is stable, you can fix it by using caulk (it comes in tubes for a few quid that you'll need a sealant gun to apply). I'd suggest getting good flexible, paintable caulk - rather than one of the cheaper ones that doesn't flex too much.
It's a cheap fix and easy to do, but if you've not used caulk or a sealant gun before, I'd watch a youtube video on it first, as you can make a mess with caulk if not careful.
