Cooker control unit as spur for additional light circuit?
Hi guys
Need some advice. I have wall lamps in my bedroom with cables running vertically down to the wall socket below. In order for this to be compliant I need a fused spur. However i can't add any boxes on the wall since i have it covered with panels which I'm not planning to remove. Wall socket is a double socket so I was wondering if i can replace it with a cooker control unit as spur for this light circuit? I would need to replace the fuse to 3Amp but it would solve my problem without need to tear down the panels.
In my mind it should be ok as cooker control unit is a wall socket with a switched fused spur. Or am I talking nonsense?
Exceed the code if you can. A lot of pain and loss went into developing the suggestions for the basic code.
