Central heating clock us
The display on my central heating clock ....... A Lifestyle model LP711 has stopped displaying the usual information...is there a fix or do I need a new one? Many thanks.
Surrey
Hi.
If all is working OK - heating switching on and off as it should, and it is just a display fault, there is nothing you can do other than replacement.
If the screen is totally blank, and is not controling the heating, there could be a wiring fault.
this would depend on the boiler you have.
To replace the timer, power off. Two screws underneath, and unplug from the backplate. As with other Drayton controls, no need to replace the backplate.
Fantastic and thank you. Found the two screws removed the timer and as I removed it the the display returned after a three day holiday!!!! Timer replaced and display still there. Thank you for the time you tok to respond .....those screws were not obvious!
