Bosch FridgeFreezer KGV3604/05
Patagual Concepcion Chile
This is not a UK Model but sure is similar to many.
Electronic control does start/run compressor.
Did I read somewhere that the Fast Freeze button should bypass the Thermostat?
(I can "manually" start the compressor, via the comp connections: That is fine.)
I have been quoted around £200 for a replacement PCB: But not confident it will be the right one....so it would be an expensive mistake. (I'm living in Chile: No Refunds!)
I have considered fitting a manual Stat.....where best to locate the probe?
The unit is in excellent condition, it would be a tragedy to have to scrap it.
Thanks in advance.
