- Joined
- Aug 19, 2019
- Messages
- 107
- Reaction score
- 15
- Country
Hi
I was mowing the grass a few days ago and the mower suddenly cut out at first I thought that grass was clogging the blade but this was not the case. I tried it again and switched on and died. I could not restart it again until it had sat for a bit. I suspected the thermal cut out. I removed the mains supply and turned it over. I found the blade hard to turn. After dismantling the motor I was able to spray some wd40 into the back of the motor bearing to clean it out as was dried out and stiff to turn. I left it overnight and then repacked the bearing with lithium grease. The spindle now turned freely. I put the motor back together but have found that once the armature bolts are tightened the motor is again tight to turn. I reinstated the power and the mower is still in the same state. If the bolts are slackened a bit then the motor turns more freely but I haven't tried to run it like that.
Cheers
Dave
Cheers
Dave
