I’m trying to install a new “smart” thermostat, but it needs power, unlike the battery powered thermostat I had before. The most straightforward approach is to use a “C” wire but I don’t have one.
I have an American Standard gas furnace with central air. Looking at the control board, I do see a terminal marked “C”, used for something else. The cable to my thermostat has an unused wire: can I just connect it to the “C” terminal?
looks like the existing wire at that terminal (and the red on the other side) heads outside to the compressor. Will this terminal feed the thermostat adequately without interfering with AC? Do I need tobe concerned with multiple connections to the same terminal?
