Toilet Draining Issue
I have a relatively new toilet that has started getting clogged when there is nothing in it. Most of the time it works fine but sometimes it'll just have a few pieces of TP and some urine and when you go to flush it it clogs. I run an auger through it and it unclogs. Sometimes if you just wait the weight of the water will unclog it. I used an endoscope and couldn't see any obstruction. There isn't a chance that there would be toys / hygiene products in the toilet. So not sure what is going on. Thoughts anyone? Thanks.
Could be something wrong with the air pressure in the toilet piping. Do you know the PSI?
Snake the vent. Or use a cleaner from the roof. You may be breaking a vacuum with your snake.
