How to locate and access the low voltage transformer in a conservatory with an apex
ALP
Berkshire
I have a conservatory, with an apex in the roof, and there are four lights there.
These were 50W halogen low voltage bulbs, so I swapped them for low wattage versions, and they don't really work.
I want to check on the unit that does the "low voltage-ing", as I suspect it must have a minimum load, and so I should be able to replace it for one that will work - if only I can locate it, and access it!
I have been able to track wiring from where goes up the beam on the roof to the apex, and can see wiring in the apex, but I cannot see the low voltage thingy!
I have also been able to see how to release the apex trim to get a better look - but neither side seems the show a low voltage thingy - nor can I see how to remove the fascia to see if it is hidden there!
I am also just wondering if the low voltage thingy may be in the covering for the guttering, but I don't know if there is the space - or if this is a practical place to have the "thingy"!
Any advice would be most appreciated.
Many thanks,
Why are you swapping out the 50W? Are they too bright or do you think you will save electricity?
ALP
Berkshire
@Marty - many thanks for the question. The 50W were taking too much power (200W in total) so I wanted to reduce the power consumption, an got some "compatible" low voltage devices, so now all I would like to do is to be able to access the wiring - which I cannot get to, without taking down (in part) the fascia. Once I can do that - without damaging it - I will be able to replace the driver for a version that will support (ideally) both LED and halogen lamps!
wtr
