Help
i have changed fuse for central heating but accidently ussed the a 13amp fuse instead of 3amp fuse. This blow the fuse. I then bought and changed to the correct fuse but still is not working. What do i need to do to get this sorted?
up the junction
It may be that a fuse further down the line is blown, failing that get an electrician Ritchie, the last thing you want to do is any further damage...bosshogg
oops!! seems like your system is blown up with the fuse.. call an electrician around you.Please dont try anything at you own.might be you completely lose your heater. :(
