- Joined
- Apr 23, 2021
- Messages
- 5
- Reaction score
- 0
- Country
I am installing a stainless steel work sink. I researched as much as I could. Are these the parts and materials I need for this install? I have FlowGuard Gold, which is CPVC I believe. I believe the drain pipe is 1 1/2".
2 Keeney Brass 1/2-in FIP x 3/8-in Compression Quarter Turn Angle Valve
2 Charlotte Pipe CPVC Adapter
1 Christy's PVC Pipe Cement and Primer 8-fl oz PVC Cement and Primer
1 Oatey 0.6-in x 43-ft Plumber's Tape
1 Keeney 1-1/2-in Plastic Sink Trap J-Bend
1 Keeney Brass 1/2-in FIP x 3/8-in Compression Quarter Turn Angle Valve
1 IRWIN 1.5-in Multipurpose Pipe Cutter
1. Turn off water
2. turn on faucets to drain water
3. cut existing pipe
4. apply primer then apply glue and install adapters
This look like a solid plan to you guys? Anything I am missing?
1. Turn off water
