Hi everyone, I’m looking for some advice on the best course of action to fix a damp patch that is around 1.4m high on a newly plastered wall.
So the entire house has had a damp course recently. The damp plaster was removed up to 1.4m high then damp injections and a damp membrane was fitted to the wall before new boards and skimming was done.
Unfortunately I didn’t knock off the plaster on the entire wall and just removed old plaster to around 1.4m high and skimmed the entire wall instead.
I now have some strange damp patches on the chimney brest wall that is in the exact spot where the new plasterboard would have met the old plaster (see attached image).
At first I thought it would be the chimney needing capping off, however the damp patch is midway down the wall rather than damp at the top of the wall which is normally the case with an open chimney that is letting water in. The highest points of the wall are completely dry.
I’m wondering whether this could be caused by damp bricks that need to dry out and so am considering hiring a dehumidifier, but would appreciate any advice before doing this?
Thanks!
Thanks!
