Bathroom rap - repair or replace?
We have an upstairs toilet and the hot tap is loose, causing annoying loud vibrations through the pipework. It's worse when water runs elsewhere in the house (e.g. toilets flushed, shower used), but does it sometimes as well when nothing else is in use. It is also leaking inconsistently, allowing a steady trickle of water.
Any ideas what this could be, or would it be simpler/easier/cheaper to just replace the tap(s)? I've never done anything plumbing-related, but I've been told replacing taps is fairly straightforward with patience and the right tools.
