60+ year old concrete slab needs lifted
Will the age of this slab prevent slab or mud jacking? It is sunk creating an 1.5" ledge and has a 12" wide crack that I would fill provided it could be raised. Slab is 12' X 8'.
Need to consult eith the concrete professionals and get some estimates. Cheaper than r and r.
Age should not affect it unless it is an issue. The crack ia the only issue?
Thanks, pros are going to take care of it following pole barn construction. Did not see any problem from two pros. I will need to patch cracks though.
Thanks, execs area unit reaching to watch out of it following pole barn construction. failed to see any drawback from 2execs. i will be able to have to be compelled to patch cracks although.
Staff online
