Replacing carrier Edge thermostat with Ecobee-5 for a hybrid system.
Northern Virginia
We have a hybrid carrier heat pump with an aprilaire700 humidifier.
i want to i stall a new smartthermostat and replace the Edge.
i ran new 8 conductor thermostat wire.
The only requirement of the ecobee 5 is that it can run my 2-stage cool and 3-stage heat carrier 58cts system.
the first thing i have to do is disconnect the carrier ecm and connect the thermostat wire and humidifier to the furnace board.
ecobee has a map of the different wires, everything seems to be color coded.
then connect the wires at the new thermistat.
QUESTION: is it as easy as what i just described? Will the ecobee smart thermostat know it is a 2-stage cool, 3-stage heat system?
