Plumbing advice
Hi all,
I have just hit a snag in the installation of my new kitchen and am seeking some advice with the plumming of a new sink. The problem im having is the new sink is undermount and has lowered the p trap to a point below the outlet in the wall, I dont think that lifting the sink is a practical option as I will have to lift the countertop approx 100mm, my other option would be to drill a hole in the outter wall and reconnect the drain pipe at a lower level, does anyone know if there is any issues with this and is this a DIY project or should i get a plumber to advise?
Many thanks,
James
Hi all,
Many thanks,
James
Hi and welcome.
Depends on your DIY skills and what tools are to hand.
I wouldn't think twice about drilling a hole in brickwork if necessary.
I could do it with my twenty year-old B & D hammer drill, with a masonry bit long enough to go through both walls.
I'd drill a hole rxactly in the middle of where I wanted the hole to be, going through both walls, making sure it was straight and horizontal, then stitch drill it from both sides, using a more manageable length masonry drill bit.
Here's a video. I've used the same method for the outlet for a tumble dryer vent.
