Plumbing nightmare - advice?
Speedy Jim
My new bathroom sink drain comes down not even close to the drain from
the wall -- see the photo here:
http://public.fotki.com/JKdrummer/plumbing-nightmare/dsc00510.html
I have the pipe from the wall in as far as possible the drain and the
pipe from the sink are off by about 1-1/2" any advice?
JaKe
This wouldn't be my first choice, but you may be able
to make a flex section work. Insert this in the sink
tailpiece:
http://www.watts.com/pro/_products_sub.asp?catId=68&parCat=796
Another way is to put a 45 offset right at the wall,
using DWV fittings, then transition to the tubular trap.
If you decide to make a rigid (rather than flex) fix,
draw up a plan view with dimensions so you can see what
fittings will work.
Jim
Plumbing inspector nightmare 51
Plumbers Nightmare 9
Curtain nightmare! 4
wallpaper nightmare 4
SORN nightmare 27
nightmare job 13
Aqualisa Shower Nightmare 2
Home Inspection Nightmares 26
