new wireless doorbell fails 4 times
Zenith model wireless doorbell from Home Depot ( only models available), works erratically when holding outside at door but never when attached to door frame. Tried four styles.
Welcome to the forums. If you bring the bell and button closer, does it then work? It could be a problem with range or interference, so you may need to try another brand with a hopefully stronger signal (or just go wired).
B.C. Canada
It sounds like there may be something shielding the signal between the doorbell and the receiver. Usually this is the result of a large piece of metal. If you have a metal door or even an aluminum screen on the door, this could be an issue. The signal will spread out from the transmitter, but depending on the frequency, may not diffract (bounce) around objects well. Heating ducts can also interfere with signal transmission.
Test the bell and ringer in an open space to get a feel for the distance it is broadcasting. Look to repositioning the doorbell or receiver to avoid any obvious metal shields.
