Lights Flicker
Our kitchen lights flicker once ever-so-often. We have a kitchen area split into 2 sections with a dimmer for each section as well as normal switches at the other end of the room. 1 section has 10 bulbs the other section has 15 blubs. The blubs are all Saxbys LEDs 7w dimmable.
Is there a way of me testing or trouble shooting to find out what is causing this?
175W of LED lighting for one room? o_O
Anyway - when you say "flicker once" do you mean they go dim/off for a very short dip, and then come back on?
All 25, or just one bank or the other?
Any other lights on the same circuit affected?
As a service/trouble electrician, here is what I would do. Swap the two (2) dimmers. If the problem is now manifesting itself on the other section of lights, then your problem has been narrowed to the dimmer, that is, you've a bad dimmer. Try that. Let me know.
