laminate flooring
Hiya what are the best jigsaw blades to cut laminate flooring. Do i need ones that cut down or ones that cut up. Im assuming the smaller the teeth the better.
I used a tenon saw, harder work, but you're only cutting downwards.
A jigsaw vibrates, as it does when cutting plywood, with this it disturbs the laminations.
