Inlet valve leak
Miele W1613. The inlet valve on a bench test will hold mains pressure when off but will allow free flow of water in reverse direction when off.
Is this a faulty valve or does it act as a one way valve instead of an on/off switch?
Water leaks at it's connection to the water path unit. The machine works perfectly well otherwise.
