I have a question We have machines that need a fan and duct work to suck air and ventilate the air outside. We have a 2hp fan that is 1500 cfm. Couple of questions.
1: we have a roof stack with a cap on top. The duct is galvenized, it runs about 15 ft from fan to the exit. There are 2 45degree turns using 6in duct. Is there any chance we are over powering anything?
2: we want to connect to machines to this same fan. This will require connecting 3 ducts using splitters or what ever they are called that all funnel into one input of the fan. After that it follows the same rout stated above. - the machines are about 5ft and 15ft away from the input of the fan. And there will be one 90degree elbow.
Do you see any problems with this ?
Attached is a photo of the fan inside a box to isolate sound. From there the duct goes up then there is a stack in the roof.
with question number 2. There will be two machines connected to this one box (the fan) you see one big machine and there is a smaller machine to the right on the other wall.
ideally we would like the one fan to suckair out of both machines. We also want to make sure we are not possibly causing an issue with such a strong fan and 6in duct as shown. We also want to make sure the fan IS strong enough to pull air from both machine. One machine uses two ducts to be connected to fan. The other machine uses one duct. And the fan has one input. So we will have to connect all ducts together to funnel into the fan etc..
thanks I’m advance
thanks I’m advance
