- Joined
- Jan 19, 2013
- Messages
- 5
- Reaction score
- 0
Hi All. Hope I'm doing this right as it's my first post.
My query relates to installing a shower pump in my old gravity fed system. The supply presently is as follows:- Cold from the base of the cistern in the loft. Hot from low on the hot tank overflow also in the loft. I intended to install a Salamander CT50 into the supply where the present H & C pipes lay on the loft floor before going vertically down (Embedded) in the bathroom wall to the shower head. Seemed to me that the pump if installed straight into the present system would draw air into itself from the hot overflow take-off. I planned to fit a Surrey flange into the hot tank (Below the loft & same floor as the shower) bring the new hot supply up into the loft and supply the pump in the loft. The cold would remain as before, supplied from the cistern. I've been told that this would not work as there would not be a positive supply to the pump and the pump should be fitted in the airing cupboard next to the hot tank. Possible to do but very difficult to achieve, no space in the airing cupboard to fit a pump. It would require a major re-plumb, to much for me at least. What I find difficult to understand is that if the present system supplies a reasonable shower, albeit with not much pressure, then with a hot supply from the HW tank and existing cold from the cistern surely there would still be enough positive supply provided from the cold tank above in the loft so the pump could boost this to a satisfactory pressure without a problem. Attached sketch to maybe explain it a little better. Any advice and help most welcome and many thanks. Regards, Tony.
