F&P Washer won't drain
I have a F&P Washer IWL 12. It won't drain water out. The pump works, it turns on and will recycle the water. So, I replaced the diverter valve as it seemed logical to me that was the problem. Same issue with the new valve. In the diagnostics mode, I put some water in the tub and turn the pump on, it comes on, but no water is pumped out. Funny thing is, if I turn the valve on to recycle the water, as the valve moves water starts getting pumped out, then stops as it finishes the position change. Now, when I turn the valve off, it will start, and continue, to pump the water out until the tub is empty so I'm pretty sure there is no clog. But, if I turn the pump off during this, and then turn it back on, water quits draining and I have to turn the valve on/off again, then it drains. Any suggestions??
