extend clean out
Hello
I am putting drywall up and my clean out doesn't sit far enough out so will need to extend it.
Also when extending the clean out would like to put drain for my boiler and direct hot water systems condensate. As well for draining floor radiant pipes when needed.
Ideally would extend the clean out and put the other drains there as well.
I thought to the right of the clean out where the pipe comes down putting in a tee but the height is pretty tight for the drains.
In one of the pictures you will see where the drain is now. It doesn't work very well, I know the problem and not going to rip up the concrete to fix.
