Checking Level of Mower Blade(s) Made Easy
Leave the tape measure and anything else you've tried in the tool box and for sure the leveling devices for sale in the store.
On a flat surface, level isn't necessary, but a gauge you built as a DIY'er using a couple pieces of lumber and a strip from your Styrofoam drink cup will tell you everything you need to know without attempting to recall any numbers. If you only have 1 indicating mark after checking left and right, L and R is perfect. Also check front to rear blade tip cutting edge height if desired.
