Cartridge taps
I've just moved into a bungalow that has a number of taps containing cartridges that control the temperature. Due to these (and the long length of flexible 15 mm plastic pipe that the water has to pass through on its journey to the tap) it takes a fair bit of time to get enough water in the bowl. Is there any way that I can remove the cartridges from the taps?
Also.......are there any safe :confused:way of speeding up the water travelling through the 15 mm plastic pipe?
