I was going to put peel and stick, TrafficMaster Carrara Marble 12-inch x 24-inch Peel and Stick Vinyl Tile (20 sq. ft. / case) Home Depot, over existing vinyl floor. When I removed the base cabinet for the sink I found how bad the floor really is. So I have ripped it up, well in the process of ripping it up, down to concrete.
Seems the first flooring level has a paper backing, what is the best way to remove all this. I have found by wetting it, the paper comes up easier, but still need to scrape a lot.
Should I after removing as much of the paper as I can by scraping use my angle grinder with wire wheel to make sure I get it all?
Prior to laying the peel and stick what prep to the concrete should I do.
Thanks.
Thanks.
