Bladderless Air Water Pressure Tank
I have a 40T bladderless water pressure well tank that has lots of air that gets into the fausets in the home. I have a WJ valve with a gauge. There was no air bleeding through this valve. I have backed the nut and made sure the bleed vale is not clogged because there was no air coming out. After doing so the air came through. Should air continue to come out this valve even when the pump is not running because it is now. It seems like the pressure is falling slowly while this air is venting out. How can I keep the air from getting into the lines going to the house? Is the valve bad? After venting the air the first timeand tightening the valve and nut so no air vents, it seemed ok for a few days. Then it seemed like the air was coming back slowly into the lines. What should I do next?
