Vaillant F75 Fault Code
London
The Vaillant F75 fault code often indicates a problem with low water pressure. This can be caused by issues with the water supply, pressure sensor, or even a leak in the system. To resolve this, you should check your water pressure gauge and ensure it's within the recommended range. If it's too low, you might need to repressurize your boiler following the manufacturer's instructions.
