Phillips hostess trolly
I have a quite old Phillips hostess trolly and the thermostat is stuck on hot , can it be repaired or can i replace it?
With a lot of appliances the fabrication, often consists of some bought in parts. So it should be possible to get a replacement if not from Philips. I'd suggest unplugging it and removing the thermostat it may have some identification markings on it.
I've no idea what model you have but I found this on eBay in less than five seconds.
If it isn't the right one, you could make more searches. It shouldn't be a problem to find one. I noticed that elements were also availaable.
https://www.ebay.com/itm/Hostess-trolley-side-buffet-server-thermostat-Philips-EKCO-/252898683751
Thank you , I've checked but not the same however I will check for what I have.
Regards
Mary
