Kärcher wd 2.200 motor disassembly - Need some help
Norway
Hey. As the title states I ran into an issue trying to get the impeller cap off. I have done this on several other motor/pumps with no issues so I'm kinda puzzled. Usually I use a flat screwdriver and few light taps with a hammer. However this does not seem to work. The motor is a dw-pc from kingclean. Any help/advice is most appreciated .
Best Regards John
Bulgaria
Hi, we had issue with high pitched noise with our WD2. Also could not open the cap you mentioned but gave it a bit shaking and then spraying it with fast drying contact cleaner spray so to make it as clean as possible. After that sprayed some lubricant and closed it back. It sounds like new again. Hope this helps.
Ayrshire
Sorry. but I have no input as regards the actual repair, but?
Have you looked at U-Tube ? there may be a strip down video for the particular machine you have in your country?
Ken.
