electric shower no pressure
Hi
Hope someone can help.I have fitted an electric shower which takes the cold water feed straight from the water tank in the loft. The tank is not raised so just sits on the loft floor.The problem I have is there is no water pressure to the shower. I went out and bought a shower water pump thinking this would solve the problem. The trouble is the water enters the pump from above but the pump is level with the tank.Therefore there is no water pressure going into the pump. I can not raise the tank so all I can think of doing is breaking into the main cold water supply under the bath and use the tap pressure but this is something I dont want to do
I would just perfer to have the water coming straight from the tank to the shower but need some pressure
Any help would be gratefully appreciated
Many thanks
Phil
wtr
