corrugated roofing closure strips
Hi:
I have a home that has corrugated metal roofing, it was installed 9 years ago without the closure strip between the roof and outside wall. I am looking for suggestions to seal the openings, a variety of insects have decided that our attic is good place to hang out,
Thank you ........
up the junction
Assuming you can get to the underside of the profile of the sheets,strips of both profile and comb fillers are available. Depending where you live, most roofing companies doing profile sheet roofing would be able to supply, or even flebay. Profile filler strips are made of polystyrene foam (or similar) and can be pushed in to close gap, plastic combs are flexible and can be pushed/cut to close profile but allow for breathing, available as above...bosshogg
