Can I fill this hole?
I'm looking to put flooring on my concrete floor in the basement.
I am hoping I could fill this hole in the concrete floor with concrete. Currently the hole is covered with a wooden slab.
I have a basement waterproofing system with French drains and a sump pump in a different area of the basement. Water in my basement is non existant.
My house was built in 1950. There is a washer and dryer near by, but the washer has a direct connection to sewer, and from what I can see nothing drains into this hole.
My basement also has a bathroom with a grinder pump in a different area that also goes to the sewer.
My question is, can I fill this hole with concrete? Bottom of hole is dirt.
Should be fine as long as you don't forget about some heat-insulating element on top of concrete.
rockland, ny
Looks like someone may have used that hole to hide a safe? sure fill it and use a lot of stone aggregate so you do not need that many bags of cement. You could even fill it with gravel less two inches. But sealing its is a good idea in case you have Radon leaking into your house from underground. #2 carcinogenic for cancer after cigarette smoking.
