AEG lavamat turbo (L 14710-VIT) washer/dryer will not wash?
yan
Hi, I have an AEG lavamat turbo washing machine (L 14710-VIT) that will not wash? It will start the wash cycle (rotates the drum/fills with water/starts to rotate) and then it resets the display & timer and stops. This occurs after approx 2min and on all wash progs. Drain will not work at all. Spin alone works fine. Error code is E36 but not cant find what this indicates?
One point, the dryer is only occasionally used (once or twice /yr) and last wk when all was working fine I tried to use it and after 5mins it tripped the main house circuit breaker. I reset this and havent tried it since, but now this washing problem has occured!
Main filter is clean.
Any help would be most appreciated..
